Drivers Side Defroster Vent
When I bought my car the driver side defroster vent (the long vent that runs along the bottom of the windshield (interior)) was broken towards the drivers side closest to the VIN plate (US Model). I am looking to replace this vent but can't locate one on eBay and was hoping someone on here for some strange reason might have a spare black one...... I know it's a long shot to even ask but you never know. I have gotten very lucky with this forum before. I'm not sure what broke it. I am thinking the person that installed the Sirius receiver (since removed) tried to remove the vent thinking it was something else(?) and was not aware of the removal procedure (as I'm not either). If anyone has a black one let me know and we can work something out.
Received 3,908 Likes
Garrin, talk with Ken at Britishparts (ken@britishparts) on this forum. He can get you whatever you need at a good price. I recently got a backup sensor through him. Had a great experience.
I have the same sort of problem with my car and what it appears to be wrong with mine is there appears to be fastener in the corner near the A-pillars. With those removed, the vent just kind flops around. The new fasteners should be fairly cheap to buy and installing them is easy.
Guest
Posts: n/a
Defroster vents breakingis a common problem. Try speaking to the dealer also. They should not allow such a silly problem to tarnish the Jag image. I think they can fix it under warranty or goodwill if you ask nicely.
I apparently am not capable of asking nicely hahhaah.. but then again.. my vents have not popped loose yet!
I agree with Bruce, the dealer would probably fork one over for nothing if they have never been swapped out. Even with mine replaced, I still ended up having to put just a little bit of glue on the fastner to keep the one corner from popping up when it gets cold. Annoying.
Received 2,192 Likes
THERE ARE UPDATED VENTS AND THE ROUND RETAINERS THAT HAVE BEEN OUT A FEW YEARS FOR THE POPPING UP PROBLEM. THEY HAVE A LARGE TAB ON THE VENT THAT WASNT THERE BEFORE, AND THE ROUND RETAINERS HAVE LARGER TABS THAT REALLY BITE INTO THE DASH SO THEY DONT COME UP AGAIN
Sorry Garrin, I had a set of Charcoal vents (old style) sitting around but ended up chucking them. You want the updated version anyways. Check with Ken and he should be able to get them for you. The dealership didn't do mine for free. By the way, if you have an older X-type, it likely has a red "sensor" on the outboard side of the drivers side vent. You won't find anything about it in the owners manual but from what I understand, it's a sunlight sensor that has something, but very little, to do with the cliamte control. It was discontinued on later models so just tuck it in the hole and use the new clip to hold the vent down.
Guest
Posts: n/a
hmmm I wonder if this sensor has something to do with the "twilight" setting on the nav system brightness. My car seems to be perpetually thinking it is in the dark of night. Maybe my sensor is tucked down inside my vent?
It would be cool to me to have the brightness work automatically.
Ill have to take a look one day.
I have an 02, no nav, and no sensor light thingy. Mine passenger sidevent continued to pop even with the updated vents and fastner. I chalk it up to low profile tires and terrible roads. A very little dap of gorilla glue and that sucker hasn't moved or made a noise since.
Dicque
09-19-2015 12:53 PM
