Drivers side speakers
RE: Drivers side speakers
ORIGINAL: aquill1
Hey chris have you removed the panel on the x? It seriously is the easiest thing ever...i don't remember popping any of the door panel clips at all...it was a smooth flowing process just don't forget any screws!
have you pulled the headunit?
Guest
Posts: n/a
It is really easy to take the door panels off. Just make sure, as others have mentioned, to take the screws out first. The front panels have 2 at the bottom and one in the center in the door handle area. There is a plug that hides the center screw, but that is also easy to pop out. The rear doors have one screw at the bottom and another in the center.
When I looked at my factory speakers, none of them appeared to be damaged.
Replaced my side speakers today with some infinities and that did the trick. The old ones WONT look damaged at all...trust me they are!
I decided to make my job a bit more difficult by moving the working driver side speaker to the rear that wasn't working and putting the new infinty 6 1/2's up front since they are a much better speaker.
Cant believe it was so easy...been driving with one sided speakers for a year...lol
ORIGINAL: Chris X
I always end up braking a few of the plastic clip thingamabobs on the panel, since finesse is not one of my strong points. They are cheap, but still a PITA. I can pull the head unit on the X in less than 3 minutes.
Hey kevin,
That was probably a good call on your part to put the infinity's up front!
As for the easiness of it that's why I tried saying it quite a few times because I've never taken apart a door that was that easy...not even an 1984 pontiac phoenix I owned was that easy!
Glad you got it taken care of!
Oh yes....I had to take off each door panel. The first one wasnt fun but the others go quickly. Three screws for each of the front doors and two for the rear. You have to pull on the panel pretty hard and know that your likely to break a few clips. (Use a long screw driver for leverage to get closer to the clips) You really dont need all the clips in the first place but if all of them are broke you would need to buy replacements from your Jag dealer. I was lucky I guess...only broke a few clips and was able to reuse the others.
#28
#30
