Drove through puddle Misfire on 1,3,5
Hey all today driving to work he had very heavy rain and one of the streets was slightly flooded. Driving through water must have splashed up into the engine and now I am getting misfires on cylinders 1,3,5. This happened about a month ago, but only misfired on cylinder 5. Last time I just drove it and eventually it dried out and cleared up. I tried the same this time, but the top of the engine is not even getting warm. It is an 05 Xtype 3.0.
I have had to replace a coil on this once before so if I need to do this I can. Do you think it could be something else in the wiring? When I get home I'm gonna park it in the garage and put a fan on it. Any other suggestions?
Received 3,898 Likes
jmotsch, you are on the right track. Granted, it may be severe enough that you will need to pull the intake and then the coils to get all the water out. I would then also look into possibly putting new coils on the car not so much that you truely need them but more to get better rubber in there to make a better seal to prevent future water from getting in.
Was the misfire to the point where the check engine light was flashing or just enough to cause the check engine light to come on and the car seems to be driving normally? If it is the former, don't drive it until you get it sorted out. If it is the latter, maybe it was an instantaneous event and you just need to wait until you meet the needed amount of driving cycles for the light to go out.
What codes are you getting? If you clear the codes do the same ones come right back?
jmotsch, the question comes down to how many times do you want to remove the intake. While it may be a bit more expensive to get new coils at this point, you can install new coils and spark plugs and hopefully only have to do the job once. If you try and dry things out to see if that helps, then replace a coil, then end up replacing a second one later, to then...... you can see where a lot of time will be spent pulling things apart and putting them back together.
I wont be driving until it is fixed. Did i do much damage driving about 30 minutes home from work? Im going to just replace the coils. I did the plugs about a year ago but i guess i should replace those while i am in there.
Alright gang. I spent the afternoon taking the intake off. The spark plug wells were litterally full of water. I had to use a syringe to suck out most of it. I then use my air compressor to blow out the rest. For good measure i blew a hair dryer in there for a minute too. Changed all the plugs. Put on new coils, ensuring they have a better seal so not to let water in again. Put it back together. Started and idled a little rough but smoothed out quickly. I cleared the codes and it is running better than ever.
Thanks for the support all.
smokphattys
12-18-2010 07:13 PM
