Dual Mass Flywheel? US spec
Well after an extended vacation, I'm back. Back state side and giving a go at replacing the clutch set in the X. I had a failure last fall. Car has basically sat since. Car started right up with the first turn (thanx optima). Have the sub-frame dropped slightly, more on the drivers side. Disk, plate and hydro's out/off. My question is, what kind of flywheel does this thing have? I can't really tell from my angle and don't want to drop the whole bundle if I don't have to. Is this a standard flywheel? Can I pull it and get it re-surfaced? I've done some looking online and it appears the diesel models have a DMF for sure. The US spec gas models I can't find much on. Thank you guys in advance for your assistance.
