Duplicate key (s) for 2006 X-Type
Received 3,892 Likes
The only way that you can save money on something like this is to order a blank blade and new keyfob via a service like e-bay. You then have to call around to your local lock smith and some will have the computer that will allow them to access the computer to allow accepting a new security code. That should drop the price down to around $300 or so. But, you are not going to get much less than that.
Briefly, the KEY is the mechanical part that turns the lock in the door, glovebox or ignition. To start the car, you need a TRANSPONDER (chip) that the computer will ping to get the code. Right code, car starts.
Since you only have the one key, I suggest that you check with local auto locksmiths to get prices for CLONING the transponder in the fob. Call around, pricing can vary widely. I can then duplicate your key from photos, (standard or with a fob), and he can install a chip that your car will see as being that one, original key. The big advantage of doing it this way is that it eliminates the risk of losing your one and only key in the mail or FedEx. Tell the locksmith that you will supply the key (or fob), all that he has to do is clone the chip. ANY NUMBER of keys can be made using cloned chips, and the car will think that they are the original.
Next best solution is to remove the transponder chip from the fob and glue it inside the plastic shroud, where it will be pinged. Once this is done, any key that is properly cut will start the car, forever. I can supply you all the cut keys that you like.
If there is someone near you who can run the software which mates transponders to the car, I can make and send keys with original factory chips in them, and they can tell the computer to use them.
The last resort is to send me the key and fob, so that I can duplicate the key and clone the transponder. I really don't like this idea, simply because it kills your car until the keys are sent back to you. If you do this, I strongly urge you to spend the money to FedEx it both ways.
If he were in my area, I can do the whole job (key and cloning) for under $100 (standard key), as he waits.
I went to the Jaguar sealer yesterday to have an extra Fob programed. He said it wasn't a Jaguar one and if they tried to mate it to the cr it could wipe out the computer. I think he was bullshitting me. He proceeded to quote me $ 500.00 for a key. Ridiculous.
How is the transponder chip powered once you put it under the shroud ? Is there a best location for this procedure. I think I am going to go this route. I am going to research locally for getting the keys cut but if I don't have any luck I will contact Sone about having my two extra keys cut.
It's not that he was BSing you, he just doesn't know and was being as cautious as possible. It can't "blow the computer," the computer either accepts it or doesn't. Any Texas Instruments 4D60 chip can be mated to the computer.
The chip is just a glass tube. No batteries, no connections to the outside world. It is powered by the pulse from the sensor. You want the chip as close as possible to the ring around the ignition lock, and tape it in place to test it. Start the car at least ten times, and if it works, use a dab of Shoe Goo to glue the chip in place. I advise mounting it inside the plastic shroud, but some sensor rings are stronger than others, giving you more area that the chip can be mounted in and still work. The windshield wiper wand would be a place to try, for instance.
As a follow up to a different thread (Another door key lock out (Tibbe key)) and applicable to this thread, I just today had a key cloned for my x-type for $165, to include about 45 minutes of work. Locksmith in Kingsport TN cut the tibbe key and cloned the new key chip. Interesting process. He had the tools, software, and knowledge. Not all locksmiths do. I did not get a Jaguar logo key fob that had the remote open/close (available on ebay). The locksmith provided a plain 5-pin tibbe that accommodated a chip that works on Jaguars, so it requires manually locking/unlocking the doors, which is okay since it will be my spare key.
Let me suggest you contact Tri-Cities Lock & Key in Blountville, TN < https://tricitieslock.com/ >
I suggest you try working with them directly as, technically, there may be a state law related to necessity to show ownership of vehicle, VIN #, etc. I'm not sure. I showed up with the car and the key, had the key number (original owner had entered the number into the owners manual) so it was easy for them to cut and they knew I was the owner. Chat with them and see what they can and cannot do for you. Good success.
