e-brake cable install tricks
Received 3,932 Likes
Gondolaboy, the trick that I always used was to make sure that the e-brake was released and then make sure you have about 2mm of space between the pad and the rotor. You can then use a pair of pliers to grab on to the end of the cable and with your other hand, pull the e-brake lever towards the front of the car. This should give you more than enough cable room to slide the cable into place.
Gondolaboy (06-21-2016)
Welcome to the forum Gondolaboy,
I only picked up on this thread because of a typo in the thread title which I've corrected.
If you had posted an Intro as we ask all newbies to do, I'd have seen your details and advised against putting your full postal address on a public forum.
Eel
04-05-2016 05:25 PM
