Easy TC Fluid Change
#61
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Paul
#62
My buddy and I changed the TC oil today on my 02 3.0 X-type with soom success. First, when we removed the TC drain plug NOTHING came out; not even a drop. We started by trying to use WildBill's kit but could not get it to work. The PVC elbow was too long; not the in-line section but the length past the elbow. We fell back to the gravity feed method and got about 300 ml of oil in the TC. There was a substantial reduction in noise while driving. I plan on driving the car for a week or two and then changing the oil again. In the mean time I'll be looking for a different pvc elbow.
Mark
Mark
#64
#65
After I put in 300 ml it started leaking out as fast as I was putting it in, so I stopped. I know it has more in it that when I started and will be going back to change the fluid again in a week or two. I'm going to try to find a new elbow piece that will clear the interferance. As it was, I could only get about a 3/4 turn on it. I know that we had some effect as it was much more quite after the fluid was added than before.
Mark
Mark
#66
Mark, if Wild Bill's kit isn't working, why don't you try the solution I suggested earlier in this thread (i.e., 1/2" to 3/8" male to male reducer, with a cap)? You shouldn't have the clearance issues with that setup, you'll have a built-in nipple to connect a tube to (allowing you to gravity fill above the opening), and you'll lose way less fluid when you go to put the cap on. Anyway, something to consider.
#67
#68
Dang, I wish this valve could be screwed on to the t-type transfer case. The handle might not clear the cooling fin on the transfer case. It looks to be really well built, and comes in a version with a nipple that can you can attach a fill tube to.
http://www.qwikvalve.com/fumoto-f110n-valve.html
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/47748-easy-tc-fluid-change-nipple_image-01.jpg?dateline=1373404757)
It looks freakin' brilliant, and comes in 1/2 NPT and 3/8 NPT sizes
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/47749-easy-tc-fluid-change-nplug.gif?dateline=1373404802)
video:
video:
aholbro1
08-05-2021 05:02 AM
Richard_gib
09-12-2015 07:08 PM
Wes Steenrod
09-06-2015 06:52 PM
