ECM flash needed?
2002 X-Type (added by GGG)
Hi, I recently replaced my ECM, GECM and IC after being unable to program new transponders due to an SCP bus fault.
The replacement ECM was taken from an automatic, whereas mine is has manual transmission. The only issue I have is that the ECM detects the missing TCM, for obvious reasons, so there is a permanent red light on to indicate this.
I have JLR SDD/IDS V130, but I see no option to change the transmission type back to manual. I've been reading the following thread and it looks as though I may even need to reflash the ECM.
https://www.jaguarforums.com/forum/g...ck-ecm-120658/
If someone could offer any advice I'd be very grateful.
Thanks,
Dave
Thanks,
Dave
There are no guarantees, but you could possibly get away with a hard reset. To perform this you would need to disconnect the positive battery cable, and jumper it to a ground. I usually just jumper it to the negative battery cable. I let it sit like that for a few hours, for the electronics in the modules to drain down to a neutral state. This will normally take care of the memories in all the modules. It worked for me with my body control module. The car would of course would have to relearn how you drive, and you would have to reset all your memories. For some reason the radio presets don't go away, at least on my car.....Let me know if this helps. The ECM may have been made to look for a transmission module, so this may not work. All our cars in the states are automatics, so we are only dealing with one kind of module.......Good luck....Mike
If everything else is working, there is one more thing you can do. I had to do it to my Jeep, when I was forced to put a used control unit in, because I couldn't get out of 2nd gear. A new one wasn't as expensive as a Jag control unit, but it was approaching the wholesale price of the Jeep. The Jeep the control unit came out of a jeep with a coded key, which was kind of a rare option. My dash always showed a yellow key symbol on the instrument cluster, otherwise the Jeep drove great. The Jeep dealer said he probably couldn't remedy the problem, without putting in a new control unit. Now don't judge me, but I removed the instrument cluster, or binnacle, and simply scraped the lighting powder off of the diode. If you are happy with the way your car runs, and watch the gauges, like I do, you could always do the same thing, or remove the bulb, if that is what the cluster has.....Take care.....Mike
2002 X-Type 2.1 manual Petrol/LPG conversion
Regards,
Dave
Edit: I see it's there now!
Thank you all for your advice. The car is running fine, so I may well remove the TCM fault indicator!
Charlene n John
09-28-2015 06:01 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
