ECU interchangeability
Here's the challenge. You can't even replace the instrument cluster without having to program it to the computer so the same would be true if you replace the ECU. A few independents can do it for you, but most of the time you have to go to a dealer. Other than the IC I'm not sure what other parts require programing.
Can you please interpret your use of the word "Berline"? I assume that you are using this to mean "sedan" ... because there was no X-Type model named Berline - and every X-Type has diagnostics through the OBDII port...which model are you actually referring to?
