Eibach or H&R?
Hey guys,
I think i've finally built up the courage to do this install, with the help of my friend,
Now im wondering which will be better for the X? Which will be harder, and which will be softer? Which spring set should i go with, any help would be appreciated.
Thanks,
Jim
Thanks,
Jim
I did a little research a while back and found out they are almost identical.
I have always owner H&R product with no issues.
Also remember is you have the "sport suspension" the car will not be dropped as much. Also is you are not running the Bilstein HD from the sport package the car will not ride as nice.
Also mark all of your suspension points before you remove anything so when you put it all back together you have a "base" for your alignment.
tmart44
11-26-2013 08:19 PM
FS[SouthWest]: FS - Eibach Pro-Kit for XF
duke_dallas
10-24-2013 08:11 AM
