Electrical faults.
Now theres a surprise..
I have a 2006 X type diesel classic (?) ..the carbon fibre dash so a base model.
A few things...
I replaced the turbo actuator..having had it put on a professional reader (mine does nothing) it still takes a while to start and a few seconds to come out of limp.
Apparently it is showing no engine codes.
The off side (RH) dip beam keeps blowing fuses....I suspect the way round this is to connect it to the n/s lamp.
More irritatingly, I cant open the fluffing tailgate...it has moments but has usually rectified itself after a while..now it wont open at all. I cant hear the solenoid clicking in the tailgate..is this likely to need a new one? And am I going to be crawling into the back to get the cover off and swap it? Or is there another way to get the b*gger open?
I know..I should have looked while it was working...BTW, the glass doesn't open on this one...should it?
The other gripe is the o/s door mirror, managed to break it, bought a glass but it doesn't have the mountings on the rear...are they separate or do I need to get a main dealer one?
There you are..5 problems for the price of one...........
A few things...
Apologies I thought it was the tail glass that was causing issues. If the solenoid if clicking then the problem is in the mechanism. If it isn't opening at all then I would imagine it will be a messy strip down job.
The Door mirror should be the same as Ford mirrors and have the fitting attached to the back, if not you might need to strip the old glass from the fittings.
