Engine Air Filter Removal
I found where the engine air filter box is, however I am trying to figure out how to open so I can put in a clean filter. It has a couple of Phillips screws around the front of the box and side however the engine cover block access to the rear screws. Do I have to remove the engine cover? If so, is it a straight forward job of unscrewing the screws, taking off the oil filler cap and lifting off the engine cover? I just bought a 2003 XType with 23K miles on it. The car looks like new and drives like new. I traded a 11 year old MB for this car. Please help me
Received 3,915 Likes
Adam, welcome to the forums. As for accessing the air filter, you have the right idea. Remove the 3 screws holding the engine cover down, remove the oil filler cap and then lift the engine cover out of the way. From there you will be able to access all the screws for the intake box. Lift and swap out the filters.
Received 9,011 Likes
Series1fan
09-05-2015 08:02 AM
1964Daimler
08-31-2015 06:41 AM
