Engine Bay Insulation?
I noticed that the insulation inside my engine bay is falling part, but I don't know what its called or what I can do to fix/replace it. Its the insulation that sits up against the firewall on the inside of the engine bay (I don't know how to attach a pic of it). I think it used to be black, but now looks like a bunch of shredded brown fibrous material fiber perfect for a mouse nest. It looks like it might be the same material as the hood liner. Is there an "official" name for that piece? Is there a part number? What can I replace it with?
Thanks (in advance) for your help. I figured since I'm in there anyway I might as well address it.
Received 3,898 Likes
Mama, odds are, this is something that you will end up getting at the dealership. I am sure if you tell them that you need the "firewall insulation", they will know what you are after. Doing a quick look at the places where I normally look for parts, I didn't see anything like what you are talking about. But, I am sure the dealership will be able to get it for you.
Mama Bear (07-31-2014)
Mama Bear,
You are right about the "mouse". Do to the substantial heat under the hood that material deteriorates more than any other car I have seen. Mice will build there because of the material and the fact that most X-Type owner don't frequently drive the car. I have had the rodent issue. But I haven't changed the insultation yet.
Good Luck...interested t hear the outcome
RoyLittle0
05-25-2023 02:38 AM
