Engine fan will not turn off
Graham: Did you get a chance to check the white / blue wire from the ECM to the Fan Control Module, per Dr dome's suggestion? With the engine hot and off, and the fans still running too fast and too long, check the voltage in the white / blue wire. If it's ~0V volts, this confirms the Fan Control Module must be bad. But if the voltage is closer to 12V, then the problem could originate in the ECM or the temperature sensor.
I have a 2006 x-type with a 3 liter engine and my fan will not turn off. Have replaced the FCM twice and no change. Removed the ECM today, and even with that completely disconnected, the fan comes on full blast when the battery is connected. Until just recently, the car would start and run under this condition, but it now won't start and is showing "transmission fault". About ready to have it towed to dealer. Could I have bought two bad FCM's in a row?
If you bought the cheaper internet ones = yes. Look at the ones from Rock auto, etc. To get an OEM one.
Heed #10 & #11 =
https://www.jaguarforums.com/forum/x...module-201955/
Also, member Dr. Dome has used and tested modules he sells. He's a great source for parts.
Heed #10 & #11 =
Heed #10 & #11 =
Heed #10 & #11 =
Marka
22
09-11-2016 12:09 AM
