engine fault light on
hi all had the engine fault light came on today but everything fine! no limp home mode no fault codes tried restarting the engine a few times still on still everything fine drove to garage to get petrol filled up and started engine and light gone off??? any ideas what this could be. got 91k on the odo
Received 3,932 Likes
4x4x4, the CEL light will go off by itself if the problem condition has cleared itself and the car has been able to go through 5 start cycles and was run long enough for the computer to complete a drive cycle with each start. Then, on the 6th start, it will clear the light. So, it kinda sounds like your car hick-uped and it was enough to throw a code and now it is gone. If you are wanting to know what is going on, the code is still inside the computer. So, you can still pull the code up and see what the car was having a hissy fit over.
If you go to many auto parts stores such as Advance Auto they will read it for you.
4x4x4, if you have a reader, then all you do is with the car parked, plug in the reader (port is under the dash near the steering column, on a LHD car, it is between the steering column and the outside edge of the car, tucked just behind the bottom edge of the dash). From there, you turn the ignition key to the RUN (II) position and worst case, you will have to hit "READ" on the reader.
Yes, you can use the instrument cluster to get the codes, but it will give you a 4 character code in hexidecimal and then you have to convert that number into decimal to get the code and unless you are good with match, just plug in the code reader you have.
But, like was said, if you stop by your local auto parts place, they should plug in a reader for you and give you the codes for free. Let us know what you get and we can help you out a lot more at that point.
hi all had the engine light come on again yellow one on display got the code now 1296 the light has gone off again it says multi faults bank 2 anyone know what this could be.the code in the dtc is E510 in hex which is 1296 what does the E mean???
BrentGardner
28
04-26-2024 03:08 AM
