engine managment light wont stay off
hi i hope someone can help i have a engine light on it was to do with lamder sensor witch have been done now i have a code for heater circuit faulty but no fault can be found but light stays on car runs OK but need to get light off so i can sell it help!!!!!!!!!
Received 9,013 Likes
Received 3,932 Likes
NRCgasman, tell us the codes (P....) that you are getting. That will help keep all of us on the same page. Do you have a diesel (2.0/2.1L V6) or do you have the gas motor (2.5L V6)? That can change what the problem is. On the gas motor, 99% of the time it is an O2 sensor and by telling us the code, we can make sure you go after the correct one. If it is a diesel engine, then you are looking at a glowplug issue. Again, the code(s) will tell us a lot more than you simply describing what is going on.
Originally Posted by nrcgasman
sorry its a x type sport 2ltr v6
Pretty sure diesels dont have lambda sensors either
Received 2,195 Likes
i will check whether the mechanic got the right bank because I'm sure it was b bank and he did the ones at the back near bulk head i have not got the codes it came up with i will get them from him but he is away at mo got everyone scratching there heads
idea !!!!! is it possible to remove a new fitted sensor and change it to new position that way we could check them all without buying expensive parts each time
X_Type_South_Africa
12-09-2015 05:37 PM
Fraser Mitchell
10-01-2015 04:06 AM
