I have a slow leak few drops here and there coming from under my car. I got under it and couldn’t see where it was leaking from but I took some. Crappy pictures at night of the engine and you can see the leak I believe is causing it.
My guess is it’s leaking from the valve cover gasket or something in there. Can anyone help tell me what it may be and what parts I should order before I pull it apart to replace it? I’ve pulled a apart my old s-type and replaced them before but haven’t done it on this one.
can someone give me some recommendations on what it might be or what I should check and how long the job might take?
Thanks 🙏 fam!. Would this leak cause the few drops on the driveway? Seems recent too from what I can recall. See the dark spots?
