Engine Plastic Cover Bolt
Does anyone know the specs & where to buy the bolts for the black plastic engine cover? I've seen this before posted but couldn't find it again. After a couple hours of searching the forum, I thought I just post & see if someone will be kind enough to point where the thread is.
Same with the screws for the air filter case (one with the JAGUAR name).
Thanks in advance.
Thanks in advance.
Location: That Rectangular Hole in the Consciousness of America
I just about guarantee you that if you take a nice, brilliant bright shop light and spend twenty minutes or so inspecting the top of your engine, you'll find the missing bolts.
Had the same problem; I was missing two of them from the engine shroud. Just by chance I found the first one, so the search was on and sure enough, the second one was (well) hidden away on top of the engine, also.
They are black, difficult to see, and the top of the engine where they tend to fall to is full of nooks and crannies where they hide.
It's worth a look! Good luck.
al_roethlisberger
09-11-2015 10:04 PM
philwarner
09-05-2015 10:05 AM
KarimPA
09-03-2015 07:32 PM
