Engine stutters under load with fault codes: P0174, P1549, P0171, P1000
P0174- bank 2 running too lean
P1549- IMT valve failure???
P0171- bank 1 running too lean
P1000
So my check engine light is back on in my 2005 3.0 X-type and has revealed all of the above codes, with P1549 being a new one to me. I've previously attempted to address the others for the engine running too lean. My Jaguar specialist mechanic and I previously suspected a vacuum leak, but he didn't find one. He replaced the Mass Airflow Sensor and I had him do the Fuel Filter a couple of months ago and that resolved it for a short while. However, the car now hesitates under load such as joining the freeway.
Any help on this is greatly appreciated!
Cheers,
Ian
P1000
Cheers,
Ian
Try changing the two IMT o-rings and see what you have. Simple easy and cheap to do.
That P1549 sounds like it could be a wiring issue or something with the connector. I don't think I have ever seen that code posted here before, so not familiar with what triggers it.
IMT Valve 1 (bottom) disconnected
IMT Valve 1 (bottom) to ECM drive circuit fault
IMT Valve 1 (bottom) power supply circuit fault
IMT Valve 1 (bottom) failure
Not sure which one is Valve 1. Maybe check the wiring/connectors on both.
ian20x (06-03-2018)
Thanks Alfadude.
Is the IMT ring the same as:
OES Genuine Intake Manifold Gasket
https://www.amazon.com/OES-Genuine-Intake-Manifold-Gasket/dp/B006C0RD66/ref=wl_mb_wl_huc_mrai_3_dp?ie=UTF8&pd_rd_i=B006C0RD66&pd_rd_r=N38RRPCB6KXFPV28E4YG&pd_rd_w=V5nvP&pd_rd_wg=y52d6
It looks to be from the following video:
![https://www.amazon.com/OES-Genuine-Intake-Manifold-Gasket/dp/B006C0RD66/ref=wl_mb_wl_huc_mrai_3_dp?ie=UTF8&pd_rd_i=B006C0RD66&pd_rd_r=N38RRPCB6KXFPV28E4YG&pd_rd_w=V5nvP&pd_rd_wg=y52d6](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
noterman
08-18-2016 08:11 PM
