engine temp
A typical Jag engine will run at around 194F. Some hotter for sure. But that's the norm. If your fan is continuously running you may have a thermostat that is sticking. Sometimes they even throw a code for it.....P0128. Although P0128 means a stuck open thermostat and engine temp. not reaching desired threshold, nonetheless, this code logs when the tstat sticks closed, as well. I don't know why, but it does. Not very common, but happens. Jags have ALWAYS had cooling issues, and even the new ones are plagued with them. They love to leak......if it's not oil, it's coolant.
