Engine tempature warning red light is on
I have a 04 x-type 3.0s. When I opened the door of my car this morning the alarm sounded and As I drove the car the High tmepature warning was showing on the display with a red light. THe meter was on hot with red light also. No Steam, spray, change in the car at all. I have not checked anything yet. I will start with fluid check. Any ideas about what else it could be and how to fix it.
Received 3,890 Likes
drock138, like disguay said, most of the overheat issues stem from a bad fan controller. I have to ask whether the car was overheating when out on the highway or did it start overheating after a period of in town driving?
If the car overheats on the highway, then you are looking at most likely a bad water pump, but can also be a bad thermostat. If the car only overheats in the city, then you are most likely looking at a bad fan controller.
If you want to prove the fan controller good, let me know. The check is really easy to do.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
JeffR1
09-12-2015 10:43 AM
