Engine Whine [Video]
Hello again...
120,000 km 2002 2.5 automatic, TC fluid was apparently changed last year when I had the flywheel and alternator replaced. The sound happens when the car is idling, more pronounced on turns and at lower speeds. Lifted the bonnet and it sounds like its coming from the engine, maybe a belt?
Its not the prop shaft bearing iirc, thats a much different sound that I've had with this car as well.
There's a number of threads ive gone through on the forums here as well as some videos, but I just cant pinpoint what it is. Car was fine this morning driving it but suddenly started mid afternoon. Light rain, 20 degrees celsius out.
Any ideas? PS? TC? Differentials? Pumps?
Looks like power steering fluid is pretty much empty...odd. Folks say thats exactly what it is, no fluid making that noise, sucking air?
Did some searches on here for recommendations. Dexron III...
Will this work?:
Mobil ATF D/M | Canadian Tire
Asked the autoparts desk and thats what they led me to.
Will this work?:
Does turning the steerring wheel change the sound. It sounds like my car and I pulled the serpintine belt tensioner off, bearing was very noisy. Place a long piece of wood or long screwdriver on the various engine parts and plave your ear on thye end of the handle, the noise will be very obvious when you find the noisy part. Try idler, water pump. tensioner, ps pump, and see what is the loudest.
Jaguar Forums Editor
Jaguar Press release
09-04-2015 09:18 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
