Error Codes and Torque Pro Mode $06 Report
Hello All, My name is Brian and I just got a 2003 Jaguar X Type from my parents (they passed away recently) and it is registering a couple of OBDII codes as well as failing some CID/TID diagnostics. I have an ELM327 scanner and Torque Pro for Android, so if you guys could lend a hand, it would be greatly appreciated.
I am receiving the following OBDII codes:
P0174 - System too lean (Bank 2)
P0037 - HO2S Heater Control Circuit Low (Bank 1, Sensor 2)
I was also receiving p0420 before changing sensor
I replaced the downstream O2 sensor (had a black connector) that I thought was bank 1, sensor 2, but I could be mistaken. I had to get at ti from underneath the car, and it was in the middle towards the front of the engine. I unplugged the ground battery cable before doing so, and replaced the old sensor with a Denso 234-4798.
After installing, I cleared the codes, and the car drove great for one trip before the P0037 came back followed by the P0174. Also, I noticed the car stops me from accelerating above 3000-3500 RPM by shaking violently, so I assume this is "limp home" mode. It goes away when I clear the codes.
Here is my readout from torque:
Vehicle VIN: SAJEA51D83XD***** (if you need enitre VIN, I can post)
Vehicle Manufacturer: Jaguar
Vehicle Calibration ID: JA2003FJ6MA98b
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$02 CID:$11
- Lean to Rich sensor threshold voltage(constant)
Min: 0
Test result value: 65,535
PASS
TID:$04 CID:$11
- High sensor Voltage for switch time calculation
Min: 4,500
Test result value: 10,861
PASS
TID:$07 CID:$11
- Minimum sensor Voltage for test cycle(calculated)
Min: 123
PASS
TID:$09 CID:$11
- Time between sensor transitions(calculated)
Min: 32,809
PASS
TID:$0a CID:$11
- Sensor period(calculated)
Max: 33,423
FAIL
TID:$0b CID:$11
- EWMA Misfire counts (average) for last 10 drive cycles
Min: 6,554
PASS
TID:$0c CID:$11
- Misfire counts for last/current driving cycles(calculated)
Min: 6,554
PASS
TID:$0d CID:$11
Min: 1,638
PASS
TID:$0e CID:$11
Min: 1,638
PASS
TID:$0f CID:$11
Min: 77
PASS
TID:$10 CID:$11
Min: 92
PASS
TID:$11 CID:$11
Min: 28
PASS
TID:$12 CID:$11
Min: 440
PASS
TID:$1a CID:$11
Max: 55
Test result value: 14
PASS
TID:$1b CID:$11
Max: 55
Test result value: 13
PASS
TID:$1c CID:$11
Max: 36,606
Test result value: 32,693
PASS
TID:$1d CID:$11
Max: 36,606
Test result value: 32,781
PASS
TID:$1e CID:$11
Min: 28,930
PASS
TID:$1f CID:$11
Min: 28,930
PASS
TID:$21 CID:$11
Min: 1,180
PASS
TID:$22 CID:$11
Max: 2,359
FAIL
End of report.
I would appreciate any help or suggestions on where to look next. Thanks.
Test report:
TID:$02 CID:$11
Min: 0
PASS
TID:$04 CID:$11
Min: 4,500
PASS
TID:$07 CID:$11
Min: 123
PASS
TID:$09 CID:$11
Min: 32,809
PASS
TID:$0a CID:$11
Max: 33,423
FAIL
TID:$0b CID:$11
Min: 6,554
PASS
TID:$0c CID:$11
Min: 6,554
PASS
TID:$0d CID:$11
Min: 1,638
PASS
TID:$0e CID:$11
Min: 1,638
PASS
TID:$0f CID:$11
Min: 77
PASS
TID:$10 CID:$11
Min: 92
PASS
TID:$11 CID:$11
Min: 28
PASS
TID:$12 CID:$11
Min: 440
PASS
TID:$1a CID:$11
Max: 55
PASS
TID:$1b CID:$11
Max: 55
PASS
TID:$1c CID:$11
Max: 36,606
PASS
TID:$1d CID:$11
Max: 36,606
PASS
TID:$1e CID:$11
Min: 28,930
PASS
TID:$1f CID:$11
Min: 28,930
PASS
TID:$21 CID:$11
Min: 1,180
PASS
TID:$22 CID:$11
Max: 2,359
FAIL
End of report.
Welcome to the forum Brian,
Just to eliminate one thing before everyone goes chasing after possible causes on the codes.
Has the vehicle been standing for any length of time? Reason I ask is that Jaguars are very sensitive to battery condition and a partly drained or failing battery can throw up all kinds of weird faults.
It has not been sitting for any extended period of time. The battery was actually replaced within the past 2 years.
My father drove the car until he passed away in November 2011, and my mother drove it after that until she passed away in June 2013. I have been driving the Jag daily since then and the CEL has been there since at least June (P0037).
The P0174 code came later (about 2-3 weeks ago) and is what limits the car to 3000RPM.
aholbro1
08-05-2021 05:02 AM
