Estate boot glass panel won't open
Hello All,
I see from the number of threads that problems with the glass panel opening are common. My problem started with the glass panel opening as soon as I turned the ignition. Now the problem is that it won't open at all. I've popped the cover off the switch on the outside and there's some sign of moisture, which I've dried off with IPA. This hasn't made any difference. The question is how can I gain access to the switch from inside; either to repair it or to replace it. I'm wary of trying to prise off the cover as it seems a tight fit. Has anybody got any suggestions? Thanks. Don
pab
03-25-2016 11:10 PM
KarmaPolice
03-17-2016 11:45 PM
