Exhaust Tip Sizes (2.5 vs 3.0)
Was at the mall today. Saw a baby-blue 3.0, parked. I didn't have my 2.5 with me for comparison, but it looked as if the 3.0 had larger exhaust tips than my 2.5. Not huge, and they didn't look aftermarket, just a little larger diameter oval.
Do 2.5s and 3.0s have different tips? Or did different years come with different tips? Or do you think these were aftermarket?
Thanks.
Thanks.
The tips aren't purchasable separately from the silencers and thus should be the same in the 2.5 and the 3.0. I don't think it's possible to remove them without cutting them off, see the pic by dennis here.
rclangelan (02-07-2013)
David, do you happen to know the part numbers for these two tips? I like the look of the Jag tip.
Looks like the Jag tip slides INSIDE of the opening on the stock tip, and then clamps down on the pipe? It that accurate?
One concern would be, it looks as if the tips are open-ended towards the muffler. Wouldn't that allow a TON of water, dirt and debris to be collected inside the tip?
Thanks.
Thanks.
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
When I removed the factory mufflers to install Mina's the factory tips are welded to the mufflers.
Thanks.
Thanks.
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/32759-exhaust-tip-sizes-2-5-vs-3-0-b51n2pgb2k%7E%24%2528kgrhqj-g4eyrqvregybmvjnbqviq%7E%7E_12.jpg?dateline=1360314202)
Hi rclangelan,
our cars have the same - rare - outside color! CGG eh ... ?
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
I bought that X-Type just 2 weeks ago (after I owned a very nice 1999 XJ8 Sport for a while).
And I installed the Jaguar OEM Tips just a few days ago. Part No. is - C2S38972.
And yes, they slide completely over the stock tips. Inside and outside.
Unfortunately they are shorter than the original mounted chrome pipes.
But that is barely visible and only from the side of the car if you are just a few Inches above the ground.
They are 100% stainless (I checked with a magnet), so no need to worry about a bit of dirt building up inside.
Here's where I bought them:
Jaguar X -Type Exhaust Trims Genuine Jaguary Accessory. C2S 38972 | eBay
Cheers,
David
P.S.
See page 3-4 in the 2006 Accessories brochure for the tips ...
Accessories 2006.pdf -- May 26, 2008 8:53 pm -- 1.9 meg
The following 3 users liked this post by DavidN:
Love the look! Just bought a set myself.
What are the stock tips made of? If the stainless aftermarket tips collect grime, will the stockers rust inside of them?
Also, is there any adjust-ability on the position of the the pipes? I feel that my passenger side tip sits slightly off center. Perhaps the previous owner backed into something. Must have been something soft, because there are no signs of impact (scratches, dents, etc...)
Thanks!
Thanks!
rclangelan (02-10-2013)
I've had them on my X-type for three years now. They aren't "aftermarket". They are Jag accessory parts. See them on '05 Sports, etc. with the body kits. No rusting of the original welded on tips with these overlays. Just look way better...
I wonder what would be the best way to vertically adjust the pipes? My mufflers were installed with larger tips in mind, so now with small stock-size-ish tips they look a bit wrong with a big gap between the tip and the rear valance.
Custom rubber hangers? Putting a hose clamp around the stock rubber hanger and adjusting the height by tightening it?
That way you can adjust the gap between the exhaust tips and the bumper.
If that shouldn't be enough you can squeeze the rubber hangers by putting a HD tie wrap around them and tighten till you are satisfied.
Cheers,
David
Andrew Fanshawe
09-14-2015 07:40 PM
Gerard Radimaker
09-13-2015 10:33 AM
