External temperature display
Guest
Posts: n/a
Wierd thing today, i started my car (02 X Type 3.0) (no navigation)and i turned the heater on and noticed that the external temperature was displaying 127 degrees any thoughts on what can be causing this sometimes the ext temp display will just go blank and not show anything...
You either have a bad ambient temp sensor or the control module is taking a dive. The temp sensor is easiest to replace and cheapest. If you look down at the lower bumper vains you will see a little switch attached there. Thats the ambient temp sensor. They don't go bad too often, so be prepared for some $$$ outlay if it turns out to be module. Good news is you can always use a used one as long as you get it programmed to vehicle after install. See them on Ebay fairly often. The control panel is the module.
