Factory HIDS
yes you can, simply purchase the Xenon HID head light assembly, remove the front bumper, remove the halogen head light assembly and install your new Xenon assemblies. The factory wiring harness is identical for both. It's plug and play. (new Xenon HID assemblies cost $900+ each)
If you go to e-bay, be sure to check the "adjustment screw". Normally these are already broken and the seller does not realize that they are selling a damaged part.
If you were thinking aftermarket kit. There are several to choose from.
Received 2,192 Likes
When I modded my X-type, I removed the auto levelling mechanism from the HID's and run the extra ground wire to the chassis. I never had issues with blinding other drivers. If you left the stepper motors for auto levelling in the HID's when you put them in your car, the lights will be pointing down with no chance for adjusting them. Drop me a PM if you want the PDF with the schematics so you can see the defferences.
- Tim
HIDs
Thanks for this info as i think i am in deep s*** with my headlights as well
some one has fitted these HIDs to my car X type I was told that they need adjusting, so I took it to a garage and sked them to line them up for me only to be told the adjusters must be broken, so am I looking for a new pair of headlights or can they be fixed?????
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
