fans
OK,
Your model doesn't have a relay or fuse. Your fans are controlled by the fan control module.
You'll find it under your air cleaner intake slightly to the right of it. silver aluminum box with ribs......
it's probably fried....but im sure you can test it.....
new from the dealer is about 150.
i have this same problem with my 2002, you say here is not possible only to change the module? (i have found only the module on ebay)
i was allways thinking 2002-2007 have the same cooling fan modules.
