Fast help needed,which oil to use..?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I'm about to go for an oil change and not sure if i have synthetic or normal oil,,is there a way to tell.Ive herd synthetics are the way to go.but also herd you cant go from one to the other without engine problems...I dont want the dealer to tell me its one thing and have it be the other...as well i know there is an oil filter brand to stay away from..anybody remember it;s name..there is a few questions here .and im going in a couple hours...so some help quickly would be much appriciated
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Received 2,263 Likes
I'm about to go for an oil change and not sure if i have synthetic or normal oil,,is there a way to tell.Ive herd synthetics are the way to go.but also herd you cant go from one to the other without engine problems...I dont want the dealer to tell me its one thing and have it be the other...as well i know there is an oil filter brand to stay away from..anybody remember it;s name..there is a few questions here .and im going in a couple hours...so some help quickly would be much appriciated![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Castol Edge 5W-20 or Mobil1 5W-20, slight preference to Castrol. Use whatever you can get at a good price and change it every 7500 miles max. I do mine (and my TC Case) every 5000 miles. If I used conventional oil, I'd do teh changes every 3000.
Oil (even synthetic) is really cheap compared to engines. I routinely get over 300,000 miles on an engine with no problem other than leaks; no burning oil, no fouled plugs, always pass emissions.
in Toronto we have a huge selection of oil brands, all at very low prices.
Go to Canadian tire and get whatever synthetic is on sale. Put the appropriate weight depending on the season. For now, I would put 20-50 since summer is coming. 5-40 maybe is ok too. If you live in Toronto, you must know it gets hot here in the summer?????
why would you presume that they use 5-10?
They say to follow the owner's manual for the oil. but for my 20 years of driving the owners manual is always the same for all cars.... runny for winter, thicker for summer.
Taken from Steve Hannes (US) website:
"Engine Oil: JTIS Spec (US): Engine oil (US), SAE 5W-30 ILSAC GF3, API SJ 5W30 ONLY – As the hydraulically operated VVT is extremely sensitive to viscosity changes. 5W30 gives the best viscosity range results with VVT. Never use a higher W number than 5W in the Duratec with VVT. Wider viscosity ranges or weights over 30 can defeat the hydraulic oil pump under certain temperature conditions and cause it not to respond, even though the ECM sends the electronic signal to shift. Jag service intervals change oil and filter every 10K – My interval is every 5K. Brands: Castrol GTX 5W30 (Castrol is actually recommended by name and logo in the Jaguar factory specifications dated 07/2004); most other shelf oil brands. Some believe in synthetics. JTIS doesn’t really say yes or no. Probably OK to use, but don’t take that as my recommendation. Capacity: 2.5L and 3.0L. 7 US Qts."
In short as Buck said the Jaguar recommended grade is 5W30.
Very true, and very well said....Mostly he copies and pastes info from the JTIS or OWNER's Manual..and in both cases there is mistakes and wrong information as well... For example..In the JTIS..the inertia impact switch is illustrated somewhere else in the engine compartment or other than where it really is, it's in the right-side of passenger foot well. (NA models)
using 5w30. Check the filler cap as all jags have the spec stamped on it. Using synthetic in my x-type 3ltr, but have put in additional additive that's supposed to protect moving joints- rather like a thick grease. When you do an oil change, use a cleaner to remove all deposits from inside the engine. I use K&N filters throughout- reckon they offer longer life and greater performance.
Been running Mobil 1 5w-30 for most of the life of the car. Easier since I run the same brand/viscosity in my Saab turbo, so I can stock my inventory with the same kind and not worry about it.
Been running Royal Purple in my Jeep for about 3 years due to the heavy use - towing and off road abuse. Love the stuff but it's $8 a quart.
I ran Redline in my 1985 900 Turbo SPG and put 325,000 miles on it before the rust monsters took over the body.
This is one of those arguements/discussions where plenty of answers are the "right" answer. You have not received bad advice so far from what I've read. I think you could get away with 5w-20 without any adverse impact. When cold it runs like a 5wt, when hot a 20wt.
I have used Castrol in all my cars over the past 30+ years..Recently as 2002 I started using Castrol Syntec in a New Land Rover I had and My 03 JAG has been on a diet of Syntec (5w30) since it's 1st 1000 mile oil change..Last year I changed over to Castrol Edge....
I have never had even a single engine problem or oil leak in any of the cars I've owned while using Castrol..I'm sold on it for life.
BrentGardner
28
04-26-2024 03:08 AM
CaneCounsel007
12-29-2015 08:35 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
