fault codes
Welcome to the forum kirandevineni,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X-Type forum and cancelled the duplicate in General Tech Help. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Received 3,915 Likes
Kira, based on the codes that you are seeing, I would first start with having a load test done of your battery. I know it sounds silly, but even if the battery is marginal (still ok to start the car, but not at 100%), it can cause the ECU to act up and give you random codes like what you are seeing.
After that, based on the codes, you have some CAN bus failures and other circuits that the ECU monitors. IT would appear to me that your ECU is on its way out. Granted, the shift solenoid fault code is kinda interesting, which is why I point back to the battery first.
as per the codes stated above, I found no mechanic who can fix my car. so I've decided to tow my car to Jag dealer who is located 20 miles away.
Am not sure about the cost to fix this CA/network malfunction.
can someone give me an estimate to fix those codes by dealer??
if its done by dealer, how much may it cost ??
** can I switch 2003 Jag X type computer to 2002 Jag xtype of 2.5l.
philwarner
25
06-26-2021 05:43 AM
