First CEL
8 months into ownership, I get my first check engine light. Had O'rielly's pull codes P0171 & P0174. After a little research on the forum, I popped the hood in search of a vacuum leak. Didn't take long to identify the upper IMT as the culprit. Ordered o-rings from Jaguar of Troy Tuesday, they arrived Friday, and after 20 minutes under the hood, the job is done. As stated by others, the bottom o-ring was easily slipped over the module from the outside; no need to remove the intake. CEL is off, we'll see what the next couple of days bring.
Tuned in on that note, I was averaging 14mpg on the old engine with the random misfire codes, hopefully there is a big difference with the newer motor going in,
