flickering lights
Received 3,905 Likes
Disco, is it all of the lights that dim with the dimmer switch, or is it all of the lights? If it is only those that are controlled via the dimmer, I would be looking at a loose plug on the headlight switch assembly or a plug close to there. IF it is all of them, I would be looking at a bad fuse or the wire running from the fuse to the headlight switch.
Check grounds. Different era, different car...I realize...but they do all seem to flicker, now, don't they?
https://www.jaguarforums.com/forum/x...witches-53109/
rsa760041
23
09-25-2015 01:33 PM
