FM radio reception - changing country settings - no difference
In reference to the earlier thread about the rumour that changing the setting for the country on the radio's hidden menu. I tried all choices on my long trip two days ago. there is US, EU, JP, AU.
There is absolutely zero difference in the reception strength for any of the settings. There is a slight advange to me when you select EU, because there is an option of radio volume high or low. On high then the volume is better matched for the CD and Tape functions.
when set to US the option does not exist, and seems to be set to low.
Anyway to be clear, poor reception is not changed at all by changine the radio zone setting.
My car has nav, and to access the menu, push eject and tape at the same time, the setting appear on the screen.
thanks for the update jimmy. Too bad it didn't help reception - but that bit about the volume high/low is interesting, i can't get enough volume out of my setup with Sirius, so I will try the EU and see if it helps.
I guess then maybe an external FM booster would be another option, but not one really worth the effort to me. Without a real antenna I don't know if anything would help all that much.
The FM antenna is in the rear glass, yes you are correct. And I have noticed the same thing. AM reception you can hear the engine sometimes and clicks when you step on the brake, at least in my 02. But I have a lot of extra components and junk.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
