Fog lights
Yeah they are actually changed from behind the bumper. You should take the wheel off though to make it easier. Then remove the tire liner plastic piece and your should be able to feel around for the fog light. You have to twist and then the housing pulls out and you can replace the bulb which is an H1 bulb.
Received 9,013 Likes
Hey Adam, Jaggys advice sounds good if I remember, although I seem to remember loosening the undertray a little that certainly helped.
H1 I think also iirc.
Surely there must be someone in the area that can help a brother out?
Shame you didn't live a little nearer to Thermo or the likes that would without doubt be willing to help I'm sure Adam
Foglight
I am going to get my mechanic friend to fix it over the weekend, I'll pick up a bulb tomorrow and hope he can do it Saturday. As described it would be impossible for me to do this job. 12 years ago I could do almost anything to a car, then the back went, had operation and it has been worse even since. Thank You all as always.
rsa760041
23
09-25-2015 01:33 PM
