Foot well lights while driving
i just would be to scared to mess with it to even try it.
Received 3,887 Likes
jvegas, this is actually pretty simple. What you will need to do is to find a double pole, double throw switch (ie, On-Off-On switch). Doesn't need to be rated for a lot of current (anything over 1 amp will be fine). Now, you will need to crawl under the dash and locate the black wire running to each light. From here, you will need to extend these wires to run them to where you are going to mount the switch on the dash. The wire running to the light you will mount to the center post. The other half of the wire you will mount on 1 end of the switch (make sure to put both of these wires on the same end of the switch). Next you will need to add a new wire running from the chassis ground to both of the empty terminals on the switch.
The footwell lights are grounded when you need them turned on. So, each end of the switch will be ground. Then all you do is flip the switch between the two On positions and in the one position they will act just like normal and the other way they will remain on. Since we are not messing with the power side of things, they will automatically turn off should you forget to flip the switch.
If you need more help, just hollar.
BrentGardner
28
04-26-2024 03:08 AM
Bcrary3
08-31-2015 11:29 AM
