Front Brakes Dragging
Hey all, I just got my brakes and rotors replaced, and they're saying my fronts are dragging. Said it either has to do w/ the traction controll or the ABS. Every ear of this before? Might my pads or rotors bee too wide? Is there a reset I need to do?
And for the time being, can I just turn off the TC or pull the fuse to ABS?
Thanks!
Thanks!
Was it doing it before? If not have them put your old stuff on and refund your money. They should not be touching brakes if they cannot work on them.
Only special tools for bleeding an X type brake system is the right wrenches and a method for bleeding. Bleeding itself will not fix draging brakes IMO calipers aren't returning properly.
Now if you have a warning code for something and did before you took it in then its your problem.
clubairth1
29
05-10-2024 12:57 PM
KarimPA
09-12-2015 08:15 AM
