Front Control Arm Help Please
Hello,
I need advice on installing a new lower front control arm.
I want to know what the correct procedure is upon reinstallation does the rear bush go in first then the middle and then the ball joint ? i will be doing this by lowering the subframe btw.
mines a 2005 2.0d.
PS i have tried without lowering the subframe on the drivers side and its damaged the rear bush which started leaking oil so thats 1 wishbone and money wasted.
thanks.
mines a 2005 2.0d.
thanks.
daboss085
10-31-2012 07:22 PM
