Front Door Lights
I have an 02 X-type Sport and I don't have lights either, which I cant understand. I'd imagine the X would have come with courtesy lights, but it is what it is. It looks really easy to install them though. I plan on pulling off the door card and running wire from the door to the cabin to splice into the lights in the kick panel. Then run these wires to LED lights Ill install in the door. It seems like a very simple job, the hardest part will be to get the wire through the door to the cabin.
One other note: The little red plastic piece pops out of the door w/o having to take everything apart. If you really want to see if a bulb is in there that would be the easiest way.
WEdge, for reference, I have the upgraded navigation system, which may also include some other niceties. I bought the car used, so, what sort of options the car came with can only be determined by what I can see. I believe my car has most of the options available for 03 except for the electric front window defroster and the 6 CD changer. Pretty much all the other options are there. Lets see if we can figure this out. The drawings don't reference any "only with this package" details.
Looking at the JTIS diagrams, from MY2001.5 to pre-MY2004.25, all those cars atleast have the option for the wiring to the door courtesy lights. But, starting with the MY2004.25 vehicles, the door courtesy lights were removed. That is what I am gathering from the information that I have. Now, why the people with cars made before the MY2004.25 vehicles don't have lights, I am still researching that one. I haven't found a rhyme or reason for that.
2004 diagram
Not to be picky but the 2004 lighting diagram has 2005 on the actual document.
Door Lights
My 03 2.5L has the red door lights and they are pretty bright at night nice safety touch. The only option I think I have is the HVAC single CD player and a leather interior. other then that I don't know what other options were and I can't find a option list on line. Oh I have a moon roof also and automatic transmission.
Puddle Lights or Just Reflectors??
Appears whether your X Type has puddle lights or just reflectors in the front doors is almost random. I read that the lights were deleted in 2004 but my 2002 3.0 Sport AWD definitely only has reflectors. Here's an easy, non-destructive and painless way to check. Put a small flat screwdriver blade under the trailing edge of the lens and lever. It will pop out of the door being secured by just plastic tabs on the lens. If you have relectors you will be looking at a void in the doortrim. Otherwise you'll be looking at a light bulb!! Push lens back in place comfortable in your new knowledge....
