Front end "whining" on de-acceleration....
hi cessna
By no means am i a professional on this but mine ( also a 2004 x type)had the same thing and after doing a lot of searching I found it to be the prop shaft carrier bearing.
Seems to only happen when it is cold and always seems to be around the same speed you are experiencing it at.
try searching that and see if it might be what is happening with yours. There are a couple posts that even have links to you tube videos that you can hear it in as well
good luck.
good luck.
aholbro1
08-05-2021 05:02 AM
