Front sway bar linkage bolt is frozen
I attempted to replace the front left side sway bar linkage on my 05 x type. First of all it is very difficult to do because there is very little to grab on to on the back side, there is a circular collar, so it make it impossible to put a wrench on it. I was successful in using a small plumbers wrench. The lower bolt is completely frozen and I cant get it turn at all. I tried spraying it and all, no luck...should I just cut it out with a sawzall, and if so where would I get a replacement nut? I could take the new sway linkage to Lowes and see if I can match it up....any Ideas...Thank you...
David
David
Thank you very much...I was succesful in changing both, however i still get a light shimmy in the wheel about 70mph...i already had the tires balanced and checked the lug nuts to make sure they are tight...i was wondering because i jacked the car up near thesway bar linkage if i didnt catch the bolts correctly...any thoughts...thanks again
lOWER CONTROL ARM AND SWAY BAR BUSHINGS
Thermo....I was able to get a free assessment and come to find out that the right lower control arm and the sway bar bushings need to be changed. I found the parts dirt cheap compared to the shops prices. I imagine that there are two sway bar bushings correct? My automotive repair experience is intermediate, do you think I will be able to to the job myself. Ive read many of your responses to threads, Im concerned with the bolts being frozen, just like when I did the sway bar links. Any help will be greatly appreciated.
David
David
aholbro1
08-05-2021 05:02 AM
Tar
09-06-2015 11:24 AM
