Fuel data error
Fuel data error
After doing a long drive & the fuel tank 1/8 to being empty, all of a sudden the fuel light went up & the indicator to E (empty). So I scramble to find a station.
While parked, I use the message center & scroll to fuel & got this message - "FUEL DATA ERROR". Put some gas when I start the car, it went back to normal.
Anybody have any idea or same problem before.
Thanks in advance.
Thanks in advance.
The trip computer uses the fuel level sender in the tank to calculate the number of miles till empty. Sending units are not perfecly linear especially at "full" and "empty". I have seen mine jump from 25 miles till empty back up to 350 miles till empty when the tank got real low. I do not think you have anything to worry about.
I usually fill up when I see the readout is about 100 miles. I don't like to run it down to all but empty. One time I didn't notice how low the level was until it was about 25 miles to empty. When I filled it up the gauge only read about 1/2 tank. Took about 15 minutes for the gauge to get back to full. Just figured something got confused when it got that low. I didn't get the error message you did though. That was the only time that ever happend. I agree, it's not really something to worry about. I personally do not like to run the tank down too far as I think you increase the chances of having issues with the fuel gauge reading properly. There are a few threads on that if you search a little.
scooternva
19
10-27-2015 02:14 PM
