Fuel Gauge Accuracy
I think I can report that the fuel gauge is super accurate. I was just below the red when I filled up yesterday and then as I pulled away from the pump the car cut out & refused to restart. I checked all the fuses but all was OK. After about half an hour it restarted & got me home without a hitch. Now my thnking is that it run out of fuel literally as I pulled up to the pump and then as the engine was hot and it was a warm day any residual fuel in the system 'evaporated'. Not sure why it would take so long to then to re-prime the system unless there was an air lock, but am ever hopeful that is all it was.
Actually, when the car dies out due to gas being absent in the system, it shouldn't take half an hour, but it will take about 5 minutes of constantly trying to start it. Now what I would be worried about, is that you filled up, so the car shouldn't have had any problem taking off and staying on. Sorry if I'm worrying you again, but you shouldn't have thought of leaving her!
Guest
Posts: n/a
most cars have a fuel return line and if you run dry, the line from the tank to the fuel injectors will self-prime. The X type has no return line. If it is full of air, one way to get it out is to crack a fitting at the engine. (a bit hard to do) or crank the engine until the injectors let all the air out.
I dont think time has much to do with it on the X type. the air wont get out of there all on its own.
Guess the deciding factor was probably not leaving the half hour then but the accumulative time cranking the engine.Not sure how many gallons it took to fill but was about £52 of fuel. Sure we have had morethan this in before? Maybe time to check the fuel filter just to be sure.
Received 9,010 Likes
