Fuel pump relays
My check engine light is on in my '03 X Type 2.5L and the code says it's the no. 2 fuel pump relay. Can't find its location via the manual and no luck with Google. Anybody know where it might be? I presume there are two relays and are they both the same? The car seems to run fine so why are there two and what do they do? Maybe too many questions but how else do I learn. Thanks in advance to all who reply.
1. Post the actual code.
2. hope a mod moves post to X forum
3. elec guides are in free download in X-Type forum stickies & on JagRepair.com - Jaguar Repair Information Resource
GGG (11-30-2020)
Received 3,898 Likes
Syd53, please post the code, that is going to tell people like me a lot more than you think. I think you may be confusing things a little bit as your car does not have a fuel pump relay, let alone 2 of them. Relay R11 in the engine bay fuse box is also the fuel pump relay for the X-Types that have a 2.0L engine (hence where someone may get a 2nd fuel pump relay from).
With this being said, your car does have 2 fuel pumps. The fuel pump that you see in the diagrams is what pushes fuel up to the engine. the second fuel pump is only activated when there is too much of a fuel level difference between the left and right sides of the gas tank and this pump pulls from the left side and moves things to the right side for the main fuel pump to pick up the fuel to send to the engine.
