funny noise from tranny?
Car is a 02 x-type
There is a funny noise that seems to be coming from the torque converter--I put it up on the lift and verified that the t. conv. bolts were tight and they were --and the flywheel(or flexplate?) didn't seem to have any cracks from what I could see....so...my question is where can I find a reman torque converter, new flywheel too--??
Now, I just put in a new transfer case and the only leak I can find seems to come from the torque converter seal I'm guessing...the trans. oil level is fine, too ..
While the car was on the lift I put it in drive and let it go and the sound is definately in the converter area...
Update
Finally got the noise to come back so I put it on the lift and put it in drive and found out it was the driveshaft making the clacking noise -- between the transfer case and the carrier bearing so I guess when the old TC locked up it must have damaged the driveshaft---whew did not want to remove transmission....
baskervillema
10-01-2015 06:43 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
