Fuse 37 30amp blowing
Received 3,930 Likes
Paully, I would start with unplugging the power plug to the blower motor. If you can turn on the dash stuff and the fuse does not blow, then odds are, your problem is the fan binding up, leading to an over current condition. If this is the case, then you can remove the fan and spin it by hand. Odds are, you will find that it is not going to spin very easy. You should be able to spin it by hand and have it spin for 5-10 seconds. If you find it only spins for a second or so, then you have bearings or a stator that are failing.
Paully (09-27-2019)
Thanks for the help yes the fan was stuck managed to free off and test working but only on maximum I think because the fan a bit stiff not blowing fuse so I’ve ordered a new unit from eBay £44 just glad I can de-mist the screen again thanks for replying I’m new to forums but they are better than any manual
