Fuse F2 keeps blowing
This just started happening today after I changed my transmission fluid.
I first noticed that when I hit the brakes my radio display dims, the "lights on" indicator on the dash lights up dimly, half of the button backlights come on (like when you have your lights on at night) and all four of my sidemarkers light up. I started looking around thinking the fix might be as easy as replacing a blown fuse. I found that fuse F2 under the hood was blown so I replaced it. As soon as I turned the car back on and hit the brakes the same thing happened again and the new fuse was blown too.
Do you guys think I have a bad relay somewhere? I think I may have shorted something because I had the battery out to access the tranny fill plug and when I put it back in my wrench hit something while tightening the cable around the positive pole and arced it. I looked up the fuse in the manual and it says "Front fog lights, master light switch" and it is a 15 amp fuse. All the lights are functioning normally except the fogs which I can't test because of some bad ballasts
Received 3,887 Likes
I was getting ready to say that F2 is what powers your fog lights. If that fuse is blowing with the fog lights off, then your problem lies where the fog light wiring (a green/white wire) crosses with your side marker lights (orange/green wire). That would most likely happen right around the battery area. Like I mentioned before, you will need to remove the battery and do a detail inspection of the wiring in the area. I bet you will find that you have a pinched wire under the battery box.
Malihide
04-02-2016 04:05 PM
