Fuse Keep blowin on my x type
Old 11-22-2010 | 04:28 PM
Tippo's Avatar
Unhappy Fuse Keep blowin on my x type
Hi Guys can someone please tell me why F75 fuse keeps blowing or what the cause could be? As soon as i replace it blows straight away!!!!!!!!!
2002 2.0l v6 x Type
Old 11-23-2010 | 04:54 PM
TheSeeker's Avatar
Fuse F75 ???
I don't have a fuse F75 on my 2004.....they only go as high as F23 in the engine compartment and F56 in the passenger compartment.
Old 04-01-2022 | 11:56 AM
Kparker619's Avatar
Default Fuse
2002 2.0l v6 x Type
Did you ever find out why Im having this same issue
Old 04-01-2022 | 01:43 PM
Thermo's Avatar
Kparker, let me get home and I will look at the diagrams for you. IT can only be but a few things. We can figure it out.
Old 04-01-2022 | 06:45 PM
Thermo's Avatar
Kparker, I think we can rule out a few things and then that will make the rest pretty simple. Do you have the fold flat mirror feature. If you do not know what I am talking about, then no you don't have it.
Next, do you have the active security system for your car that will sound an alarm when you say force a door open or the like? If not, then we can rule that out.
Assuming you don't have fold flat mirrors and the active security system, then that pretty only leaves your climate control module as the suspect and based on what other members have experienced, that would be a very likely suspect.
If you do have either the fold flat mirrors or the security system, then I would say you need to access the center of the dash and unplug your climate control module and then install a new fuse into F75. If it doesn't blow, then you have proven it is your climate control module and you are half way to replacing it. If the fuse still blows, then you have a problem with the feature I mentioned or the wiring between fuse F75 and your climate control module has gotten damaged.
Yorta2 (04-01-2022)
Cgo
05-13-2024 08:10 AM
Svalbard
03-02-2022 04:29 AM
Chris Brindle
07-06-2021 02:07 PM
mrtalkradio
XJ40 ( XJ81 )
02-24-2012 06:36 PM
frederikv12beauty
08-08-2010 09:20 AM
Quick Reply: Fuse Keep blowin on my x type
