fuse no 13
Old 06-13-2016, 05:38 PM
jagmoust's Avatar
Default fuse no 13
Hi, I've got a 2006 jaguar x-type 2.5 petrol - auto transmission. my issue is that the fuse no 13 in the engine compartment fuse box is burnt repeatedly. As a result I get "gearbox fault" signal and the abs and cheque engine lights are on.Have you any idea? Thank you
Old 06-14-2016, 08:52 AM
Lemons Racer's Avatar
Does it blow instantly? Every 6 months? Often if it blows right away you have another issue such as a short somewhere.
Old 06-20-2016, 06:53 PM
Rchiv's Avatar
Fuse 13 (5amp) is an ignition live power to the ABS module. It may be a chaffed wire (Green/White) shorting out somewhere between the fuse box and the ABS module.
Roger
rjcl004
04-26-2016 04:48 PM
Noel619
04-04-2016 08:18 AM
raze
04-02-2016 12:13 PM
andyh1108
04-02-2016 11:17 AM
hub61
UK & Eire
03-26-2016 11:08 AM
Quick Reply: fuse no 13
