gas additives thoughts/advice etc
Received 2,263 Likes
Received 3,901 Likes
Harry, like was mentioned, using off the shelf additives only benefits those making them. With that being said, a trick that you can do is if you use the same brand of gas all the time, periodically switch to a different brand for a tank or two. The reason why I say this is that each manufacturer has "their blend of additives" (and rather proud to advertise this fact). The problem comes that regardless of what blend of additives you add, something will get missed and will build up in your car. By switching to a different brand, you are changing the additives and stand a good chance of whatever Brand A left behind, Brand B is going to remove. Do this change say once or twice an oil change (on even intervals) and all will be good. No need to switch between tanks every time. It takes a fair amount of time for anything to build up in your fuel system.
With this being said, you will get more benefit from the periodic changing of your fuel filter. This should be done every 15K miles.
He didn't say there was...but that is the case today; there is no difference in the additive package between grades (generally). If there is, they'll be advertising it and charging you more (whether it actually does anything or not).
Most people are surprised by the fact that lower octane fuel burns MORE EASILY that higher octane fuels!
Why would a high efficiency high compression engine require more cleaning additives than a low efficiency engine that can run on regular?
All of the brands you mentioned are part of the top tier marketing scheme. Read what they say about putting less additives in some grades of fuel over others:
Deposit Control | Top Tier Gas
In part:
The deposit control performance of unleaded gasoline conforming to section 4 of this document shall be met at the retail level in all grades of gasoline sold by a fuel company in all marketing areas of a selected nation.
This is how I thought; To save couple of $ each tank, the average difference between reg. and premium is about $0.50, if you fill up every 2/3 of the tank with reg. gas, say 10 gallons, that's $5 less than premium, you put in a bottle 0f octane booster about $2.50, so you save $2.50 each 10 gallons, that's not much, but if you're penny pincher you save $130 a year.
Do the match again to see how many bottles you'd need to raise 87 to 91.
