Gas Door Won't Open
Had a similar problem with mine.... sometimes the spring that pops it open gets bent and it won't release when you pull the lever.
Try having someone pull the release lever up and hold it while you gently pry it open with something non marring to the paint.
If that fails then there could an issue with the cable linkage being detached.
Hope this helps....
Hope this helps....
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
